94 prelude S to F22B1
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Superaison, Oct 27, 2009.
  1. Superaison
    Superaison New Member
    I scored a SICK deal on a F22B1, running with ecu for an amazing price. My prelude needs rings really bad (190 psi in all cylinders but 2, it has 20 psi lol). So i need a rebuild or engine, but I scored a sick deal on this.
    well, what other things are needed for this swap? I currently have a 94 prelude S with 141k miles on it, and a F22A1 under the hood. the F22B1 is from a 94 accord EX.
    Any help would be greatly appreciated.
    What do I need for the F22B1 to fit in my prelude? ATM I am getting all belted accessories(I think), header, ecu, and engine with the deal.
  2. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    i think it SHOULD drop right in not completely sure though... but the accords and preludes were pretty much the same under the hood... it should have all the right mounts stock
  3. Superaison
    what about the ECU? The ecu to the other engine is for an auto, i know my f22a1 ecu will work, but no vtec, and it says here F22B1 sohc vtec into a 95 prelude - Hondahookup.com that it wont rev past 4k? is that a huge issue, or just that guy's wiring?
  4. 94civicturbo
    Liberty, IN
    get Hondata into it and get it tuned so then you can have vtec and everything set up right
  5. Superaison
    Got any links?
  6. 94civicturbo
    Liberty, IN
  7. Superaison
    I'd rather get the sockets, eeprom chips, willem programmer, etc, and flash it myself, for that price. lol
  8. 94civicturbo
    Liberty, IN
    well just make sure that allows you to run vtec
  9. Superaison
    IMO it'd be easier to get the f22b1 ecu.
    What bottleneck will I have using a f22a1 ecu with the f22b1?
  10. 94civicturbo
    Liberty, IN
    it should be about the same but maybe different fuel maps and it would be for a manual
  11. Superaison
    Well, I am trying to get ahold of a manual ECU for a f22b1, but I read somehwere the rev is limited to 4k with the f22a1 ecu
