95 accord serious issues plz help asap
Discussion in 'Accord' started by gunz2165, Nov 11, 2008.
  1. gunz2165
    gunz2165 Member
    connecticut
    i have a 95 accord that have an f22b1 which is had the non vtec head on it. i put the vtec head swap on it and now i cant get it to stop spittin. when it hits 5000rpms the vtec kicks in and around 5500rpms the motor starts to die out. my old head had a coil pack for the distributor but the new head doesnt have a coil pack for it. so i ended up using the only distributor. is this my problem? if so how do i use the distributor without using the coil pack? if its not my problem what the hell else could it be. someone plz get back to me asap. it might be faster if u email me at dragon02165@yahoo.com. plz help.:(:(
  2. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    well vtec kicks in you say so it cant be wiring or n e thing vtec issues. check the whole wiring job that you did for the coil pack and the distributor...if you just popped it on without doing any wiring that is your problem
  3. BrutalB83
    Rochester Hills, MI
    If the motor started out as non-VTEC, then it's the F22B2. The B1 is the VTEC version...
