eyesonlybob
well, i think im finally going to do a swap, and the motor is going to be a b16 (im not sure what obd it is, i havent looked at it yet). a friend from work can get me the b16, tranny, and ecu for $1000. i think its a good deal. i found the same stuff on hmotorsonline.com for $1800 i think. anyway, is this a good deal?
problem is its only the motor, tranny and ecu, so i need a lot of other parts which i can still get.
but i have a few questions:
1. im not sure if the motor includes the mounts, if not, do i just get the mounts from a junk yard say...off of a 99 si?
2. im going to have to swap my car to a manual, in doing this, which shift linkage do i use?
3. my car currently doesnt have vtec. i found a site that said which wires needed to be added, but how do i do this? just strip the wire, and add it to the correct spot on the harness? i could use some more detail about that.
4. i want to keep a/c and p/s...do i use the 99 si ones?
5. i should change out the waterpump and timing belt when doing the swap right?
6. my car is obd1, im not sure what obd the b16 is because i dont know what year it is...is there a harness that i can buy that converts everything for me (if needed), or will i have to go through that? would it be easier to swap an obd1 engine such as a b18c1 (if this b16 is obd2)?
7. does putting a new engine do anything to my insurince(sp)? do i need to tell them? any information on that would be good.
im anticipating this to go fairly easy, i have read up a lot on the swap and think im very prepared. im worried about the wiring, and misc wiring stuff. if anyone wants to point something out that i may run into so im prepared that would be nice.
am i missing anything in this list of other parts i will need:
- Axles
- Shift Linkage (which one?)
- Stock Motor Mounts
- Engine Harness (if the engine doesnt come with it...)
- A/C
- P/S
thanks
- Axles
- A/C
- P/S
thanks
