95 cx thinking about doing a ls swap need help.
Discussion in 'HYBRID -> EG-EK / DC' started by rizq777, Dec 2, 2003.
  1. rizq777
    rizq777 Member
    I'm thinking about dropping a ls into my 95 cx hb . Can i get a list of everything i am going to need for this swap. thanks
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Read the FAQ and the articles on this site, they are very helpful. You will also need know know the year of the engine going into the car.
    this might help. http://www.hondaswap.com/swap/viewer.php?id=55
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    94-95 ls engine complete longblock...hydro tranny, shift linkage from a 94-01 teg or 99-00 si, 94+ b series drive axles, 94-01 driverside mount, 94-95 p75 ecu, those are you the main things you need, get it in there and go from there.
  4. sportlinecrx
    sportlinecrx Banned
  5. DjMcPhatty
    DjMcPhatty Senior Member
    St. Louis, MO / Huntsville, AL
    Hey about a month ago i did the b18b into my 92 civic vx. Its pretty simple and straight foward if you have everything you need. Luckily mine came with everything including a new wire harness. But you will need everything the other guyz said, and some time and an engine lift to put it in the car. Good luck man, gotta love the b18's torque.
  6. redhatch92
    redhatch92 Member
    New Jersey
    Make sure you get the bracket that bolts to the motor and trans in the back to the sub frame. thta was the only problem i had when i did that same swap. i also used an ecm from a 93 teg p06 i think but youll be real happy with the differance
  7. EJdmB18C
    EJdmB18C Member
    Sacramento
    There shouldn't be any problem when the LS is in the EG...
