95 honda accord with 93 h23 motor.....
Discussion in 'ECU's, Electronics, and Tuning' started by solorican, Jul 3, 2007.
  1. solorican
    solorican New Member
    I need some help i have a put a 93 h23a1 motor into my 95 honda accord. I just purchesed this car, preiviously it had a 96 h23 motor with a integra ecu. the motor went ,i bought the car i put a 93 h23 into it and now i am having big trouble connecting the wiring. should i take the interga ecu out and put the accord one on? what type of harness do i need ? what else will i need 2 make this swap work? thanks your time and help are appreciated
  2. frannk_theshit
    frannk_theshit New Member
    doe s the engine got into the accord ????
    i got the same problem but yea you have to get thet prelude compu nd the new wiring
  3. BrutalB83
    Rochester Hills, MI
    Wow dude...if you can't even write a legible sentence than no need to respond. My apologies if you're foreign, but please, try a little harder from now on.
    Anyway, to the OP: why do you think an Integra ECU or an Accord ECU would be a good idea? How about actually using the ECU that goes with the motor you put in? Both the engine and the car are OBD1, so you shouldn't need to make any wiring changes. Just use an OBD1 H23 ECU. Check out the ECU list in the reference section to determine which ECU you need.
