95 supra white with lexus flake b swaped coupe 2k
car is bright white and the flake can be seen within 5 feet due to it being a small flake and it deep in the paint it looks like its in the paint.
ONLY TRADES I AM INTERESTED IN IS A RUNNING GSR MOTOR
AS in i am seeing it run and drive before its taken out. IF NOT THEN DONT WASTE MY TIME
good:
95 civic coupe with 95k on body and 130k on motor and trans swap.
clean wv title
DOES NOT COME WITH MSD DIZZY SETUP!!! comes with a stock dizzy.
Has new front and rear bumper and new oem hood.
comes with a p72 obd1 ecu from a gsr
new body panels
bad:
hood closes and latches some times but not all the time.
radiator leaks slightly, never overheated but needs to be replaced
paint on the car has some shity spots
comes with a p72 obd1 ecu from a gsr so its throws a engine code for the vtec shit.
header needs reflanged to fit the catback exhaust
Other then that this car runs and drives great. I would onlu hesitae to drive it because of the open header and the radiator leak
if i get 2k cash only for it and i am firm but will take close offers i will fix the radiator and get a new one put in.
car is in martinsburg wv 25405
car is not tagged or insured, so i wont tag it to drive it to you.
