96-00 Sohc V-tec Swap To 90 Crx... How Hard?
Discussion in 'HYBRID -> EG-EK / DC' started by kristoefur253, Jan 21, 2003.
  1. kristoefur253
    kristoefur253 Junior Member
    yeh i hav a 90 crx and want to swap to a sohc v tec and i was wondering how hard and how much mite it cost to get the rite mounts ,harnesses ...etc?
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    it should mount up, use your tranny b/c its cable as where that motor is hydro. Also, its obd 2, so call an electrition. You will get more power if you just do a mini-me swap. y8 or z6 head (also switch to mpfi), wire vtec and timing belt, get an Si tranny (or not), slap a lil 55 shot of zex on it and have a decetly fast car. Click on ARTICLES at the top and then ALL MOTOR HF and read up on Chets write up. A mini-me yields around 135-140 at the crank. I think the sohc vtec motor is what? 106?.. BTW, use OBD 1 parts, its easier to make them go to a obd 0 motor.
  3. VSMB16A2
    VSMB16A2 Junior Member
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    The z6 has 125 and the Y8 has 127.
  5. Domeskilla
    Fort Wayne, IN
    Ah, okay. Thanks Jeff.
  6. SolReaver
    SolReaver Senior Member
    holy shit! thats the n00biest question i have ever heard!!
    http://www.howstuffworks.com/question229.htm
    edit- i hope your being sarcastic...
  7. kristoefur253
    v-tec looks cooler then vtec B)
  8. sohc em
    sohc em Member
    Charlotte, NC
    First what model do you have Si, HF, DX, STD? because if you have the Si and the HF you will be in a better boat than the DX, STD simply because you will have less wiring to worry about and if you have an Si your tranny gearing is going to be better for performance as the other trannys are geared for fuel economy first and performance later.
