96-98 vs 99-00
spOonPLS.
Are 96-98 ek motors mounts the same as a 99-00 ek motor mounts?????
And are 99-00 civic the same as 99-00 si motor mounts????
96-00 civics are the same.
99-00 SI have different mounts, looks the same but have different bolt pattern. Only one you can reuse is the top trans mount bracket.
if your doing a swap stick with the mount that match the motor and the trans it will save you a lot of headachs
