96 Civic Dx B20 Swap
Discussion in 'HYBRID -> EG-EK / DC' started by bluescy, Mar 26, 2003.
  1. bluescy
    bluescy Junior Member
    i finally destroyed the terrible motor in my dx and i purchased a jdm b20b out of a 98 crv.
    My 96 dx hatch has a hydro tranny.... will i run into any problems with the transmission when i start the swap ? is the b20b hydro or cable ? :worthy: :worthy: :worthy:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The real problem,is that it is a 4x4.You need a 94+ integra tranny or 99-00 si.
  3. bluescy
    B) im aware that the crv's are 4x4. im trying to use my stock dx hydro tranny. will it bolt up to the jdm b20b ? i heard b series motor to b series trannys are fine as long as they are either both cable or both hydro. will someone give me a good answer ?
  4. xj0hnx
    C.C.TX.
    No your stock tranny is a D series and they do not bolt up.The ones I suggested are going to be relatively easy to find and you could probably sell the CRV tranny for most if not all the cost.
  5. EFtypeR
    EFtypeR Junior Member
    yeah, you just answered it yourself. Your stock tranny is a D and the new (CRV) donor is a B, IR the two won't mate up! You need a B series FWD tranny, preferably hydro, since that it what you currently have. If your cheap, HASport has a Hydro to Cable converter, but you will do better with the CRV or a GSR tranny from any year CRV or 94+ GSR. And to the person who said the CRV is a 4WD....WRONG...more CRV's are FWD, only a few are 4WD.
  6. bluescy
    is there any way to modify the d series tranny to work ?
    i have a cable tranny from a b series motor. how much are the conversion kits about ? :worthy:
  7. E_SolSi
    yeah get a new bell housing cast that will match up
    go to hasport.com they have them .... i still think its a bad idea though
    sell the cable trans and get the right one
  8. bluescy
    you said that only 94+ intega tranny would work...
    wouldnt a 92 ls tranny work >?< its hydraulic. and only $300 bucks with
    70k miles on it...thank you for advice thus far..
  9. E_SolSi
    93 and older are cable tranny 94 and newer are hydro
    if its hydro then its 94+ get that
  10. bluescy
    :worthy: :worthy: :worthy: ok that was what i thought.. but this guy was swearing up it down its a hydro from his 92 ls..i thought he was full of it.. i showed him the reference section but he still wont stfu about it....thank you all for your help.. ill let you know how my swap turns out... :worthy: :worthy: :worthy:
  11. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    94 and up integras are hydro below that they are cable. just be a baller and go to honda dealer and purchase a brand new type-r trans $ 2156.03 (j/k)
