OH 96 ek hb, itr swap,lsd,4x114.3, $$5000 obo akron
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by goldgreen90ef, Jul 26, 2010.
  1. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    I have decided to put my 1996 vsm(vogue silver metallic) honda civic cx(light stripped down model) up for sale. Car is located in northeast Ohio and can be seen were i work by the Stow Municipal Courthouse off Rt 8 Steels Corners exit in Stow Ohio 44221 by
    apointmemt only. I am going to try my best to describe the car and its concerns as good as possible without being too long. I would encourage you to get a hold of me and look at the car if you are truely interested. Price is $5k or best offer, or trade/cash on your end.
    DETAILS>>
    POWER
    - jdm b18c-r mobil 1` 10w30 full syn, shell v-power 93 oct
    -full jdm integra type-r swap, with itr trans with oem lsd, purchased from hmo originally,
    runs strong, vtec pops loud (oem jdm itr ecu)97 civic[​IMG] ex harness,8950 redline
    -beefy aftermarket mounts (not sure of brand)
    -oem jdm itr 3 inch intake tube with large k&n filter
    -hytech knock-off try-y header with 2.5 inch collector
    -blackworks racing adjustable in length and clock-able test pipe(great for exhaust changes)
    -2.5 inch ss mid-pipe to generic twin-loop axleback(catback needs new exhaust gaskets)
    -competition clutch stg 4 purchased in april from alex at one6motorsports, refaced itr flywheel, new master cyl, slave cyl, throw-out bearing, pilot bearing,all less than 1k on them,oem honda mtf
    -ss braided line purchased from B&R fittings,brand new, runs from slave cyl. to master cyl., with insulated brackets(important because of flex)
    -B&M fpr on fuel filter
    BAY STUFF
    -gsr valve cover painted n cleared with spark plug coverpainted goldgreen
    -itr chrome oil cap
    -diy wire tuck (could use a few things)
    -pwjdm gold fender washers and radiator bracket
    -engine bay painted battleship gray
    -hidden hid ballest
    -mugen bootie(misfits one not included)
    SUSPENSION AND BRAKES
    -jdm itr full brake and hub swap, 4x114.3 lug patteren(brakes stop good!)
    -earls ss braided lines
    -00 si struts with H&R race springs, low miles on struts, srpings lower about 2.5 inches
    -skunk2 rear lower control arms, ES rear trailing arms, adjsutable front/rear chamber
    -16x7.5 msr rims, 2 bfgoodrrich scoarcher t/a's, 2 bald falken 615's (use azzenis for dragstrip)
    -rear lower and front upper tie bars
    INTERIOR
    -pwjdm type r shift boot, integra leather shif knob, armrest with ctr type red tweed
    -civic ex auto gauge cluster
    -eg seats(modded to fit)
    -gsr rear seat(not installed, no rear seat belts)
    -old school tattoo print headliner(not perfect)
    -cd player with aux in hook up
    EXTERIOR
    -front and rear lips(front has a crack)
    -antenna delate plate
    -knock off carbon fiber wing
    -8k hid's
    **************PROBLEMS AND CONCERNS****************
    *****************READ THIS*****************************
    -3rd gear grind at higher rpm's, came after clutch job, no pop outs or other probs w/ trans
    -slight damage to pass rear quater from parking lot incident, small rust bubbles on other side
    -cracked windsheild
    -heater control cables/box need repaired/replaced,blendor door broken i think(heat blows thru the dash/vents)
    -needs tires,needs outer tie-rods/allignment
    -airbags/aribag harness/clockreel removed(horn on a switch)
    -typical scratchs ect on paint
    ************GOODS**************
    -150k on chassis or so(cluster swaps)
    -itr DOHC VTEC swap is in good running order, quick car
    -can be ok on gas if you stay out of vtec (about 30 mpg or so)
    -just needs some tlc
    Message me with questions and the price is $5000 or closest offer to that. I am considering trades on nice motorcycle or swapped civic, integra ect.
  2. goldgreen90ef
    cold ohio
    just picked up a front bumper with no holes, and a knock-off mugen grill off c-list. sanded with 800grit and used 1 can of promotor, 2 cans of duplicolor ultra silver mettalic(closest to vsm), 1 can of clear, pics taken today, sunday.....
  3. goldgreen90ef
    cold ohio
