i recently dropped a jdm gsr motor into my civic. i was curious if the iab sensor had to be wired in? when i start up my car when cold it idles about 1400 then it will go to normal but later when car is hot it will idle fine until i am at a complete stop the idle will drop to about 150-200 rpm and seems like its hard to breathe. sometimes it will idle so low it will die. the ecu i swapped is from japan and not sure what the problem is.
any feedback would be great
