96 LS/Vtec do I have everything?
Abrasintegra
What's up everyone, I want to make sure I have everything for my LS/Vtec swap. I'll list my parts at the bottom. But I'm not sure on the distributor, I was hoping I could use the one on my LS head but I don't think I can and I can't find any referances online some help here would be appreciated. Here are all the parts I'm going to be throwing on my car in this project.
LS/VTEC
-B16 p&p head w/solinoid cams etc. pluged and drilled for ls/vtec
-B16 p&p intake manifold/Throttle body
-Golden Eagle LS/Vtec conversion
-ARP head studs
-ARP rod bolts
-dowels
-Full LS gasket kit
-B16 Head gasket kit
-ITR oil pump
-ITR water pump
-GSR timing belt
-p72 ecu (still working on getting the engine wire harness)
Misc
-Phantom Grip LSD
-ACT 6 puck clutch
-Fidanza flywheel
-ITR pistons w/rings
-ACL Rod/Main bearings
-Walboro Fuel pump
-AEM fuel rail
-AEM FPR
-440 injectors
-NX wet kit
-One disgruntled wife
I think that's everything. The head is complete, it just doesn't have a distributor. I could use some reasurance before I go pulling my motor out then kicking myself in the ass for missing somthing. Thanks all. If you want you can hit me up on AIM @ AbrasIntegra1234. Thanks again.
What car is this going into and whcih OBD generation are you using, because you haven't listed your electricals and ECU?
