96 Prelude H22A ECU Problems
Discussion in 'ECU's, Electronics, and Tuning' started by jwprelude, Jul 28, 2005.
  1. jwprelude
    jwprelude Junior Member
    Hey there, I have a 1993 Honda Prelude Si with a 1996 H22A motor in it. I bought the car not to long ago and bought for a good price knowing it might need some work. My problem is, I found it has a P14 ECU Running the car however the vtec and oil pressure sensor are indeed connected to the harness. My problem is, the car ran great with the P14 Only it had no vtec. I bought a programmed ECU specifically for my engine from phearable.net. When I plug it in, the car idles weird and shakes and kind of makes a hissing sound such as the air intake. I also believe i could smell something under the hood.. Any ideas as to what I can do to get this thing running well? Thanks
    Justin
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    You might want to hit up the people that sold it to you for that question.. No idea what they did to the ECU...
  3. jwprelude
    Well I did talk to them and the ECU was tested on an H22A. It is a p28 reprogrammed to be used with a prelude. Just wondering if the previous owner did something to the car to make it run better of the non vtec ecu or what.
  4. pissedoffsol
    the map probably just isn't perfect.
    you need to tune your car yourself. some guy can get you a chip to work as a base map, but thats about it. it will NEVER be perfect, unless its a freak chance.
  5. jwprelude
    Im trying to figure out whyt the car runs so well with the P14 ECU. Is it normal for an h22a to run good off a h23 ecu? The onlydownside is the VTEC doesnt work due to the ecu not being equipeed for vtec.
