Ok i have a 96 ek dx im putting in a b16b i have a couple questions on wiring
ok the dx motor has a crank angle sensor coming from soemwhere by the crank pulley but the b16b doesnt what do i do?
If you are going to run the B16 ECU. Which you should cause otherwise the swap is pointless, you don't have to connect the plug because the ECU won;t look for it.
