97 civic - 96 integra swap
Discussion in 'HYBRID -> EG-EK / DC' started by civic507, Mar 24, 2004.
  1. civic507
    civic507 Junior Member
    ok i have a 97 civic ex and i am planning to put a 96 integra ls motor in it. I am curious to know if anyone knows any good conversion kits for not to much money, and if anyone knows if i need to change over the axels or not.
    Thanks all
  2. E_SolSi
    modify your stock harness (lengthen the wires that dont reach)
    im not sure on the mounts (some combo of your stock ones and the integra ones should work)
    use the integra shift linkage
    use the integra axles
    use the integra ECU
  3. uptowng2ic
    uptowng2ic Member
    NY
    And if have the extra cash purchase some HASPORT engine mounts
  4. civic507
    but i forgot to mention the downfall the integra is a 91 frame with a 96 motor so im not sure but i wont be able to use the axles or motor mounts, will I?.
  5. civic507
    and right now i have a 97 gsr ecu plugged into mny car so im not worried about the ecu.
  6. Tim@Canspeed.com
    Tim@Canspeed.com Member
    Use the Integra Pass. side tranny mount, 99-00 Civic Si (SiR) rear tranny bracket, 99-00 Civic Si (SiR) Drivers side engine bracket.
