I can't find anything on this with search Basically I want to replace a stock engine with the same one. No H22 swap just the same engine it came iwth. Is there any type of data sheets on instructions online for it? Or even instructions on engine removal for the 6th gen accord. All I can find are the 5th gen ones. Thanks
uhm, pick up a book from your local parts store i would recommend a helms but they are more expensive
the 5th gen one will be 98% the same thing. basically, unplug everything at the shocktowers drain all fluids remove the axels unplug raidiator hoses remove fuel line and retun line remove shift linkage chain it up... and undo the motor mounts. and out she comes. it's pretty straight forward. if it doesn't come oout, you forgot to unplug something. lol the idea is to not take it off the motor though... just unplug stuff where it attaches as a whole to the car
