98 B18c5 into EG
Discussion in 'HYBRID -> EG-EK / DC' started by Mister EG, Mar 18, 2004.
  1. Mister EG
    Mister EG Junior Member
    Hey,
    I have a 93 hatch and i am getting ready to drop in my 98 Type-R engine with a B16 Tranny. I have a few questions and if anyone can help i would appreicate it alot because i am very confused. I don't know what mounts i need??? If someone can give me the CORRECT list i would be very thankful. I am trying to find an OBD-1 Gsr ECU because i cant think of anything else that would work right but that ECU. Thanx alot
    Steve
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    teg mounts work, and get a P28 with a ITR base map.
  3. E_SolSi
    or get the hasport mount kit :thumbsup:
    im running my ITR swap in my 93 sol with a chipped P28... but if you dont specificly get the ITR fuel maps (ie: you get any skunk2 or mugen programs) you will run rich as fuck and will definatly want/need to run at least a VAFC to tune down the fuel maps etc
  4. JDMilan
    Boca Raton, FL
    :werd:, you can run the car with only three mounts, elminating the bottom two, but if you plan to have AC the lower right one in the pic is needed,
    run ITR base maps.......don't bother with the runnin rich burnt chips that a lot of peeps run.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Spend some extra cash and get the HAport mounts.
    If you are running the stock mounts, you want to run all of them.
  6. JDMilan
    Boca Raton, FL
    well, not to go against with anything you said b16vx, but I ran three mounts for a while - although I did have my upper motor mount bust on me, but once replaced it ran fine, another thing you might want to consider if using oem mounts is to make your own motor mount inserts to stiffen it up.
    www.homemadeturbo.com --> has an article on how to do it yourself, cost effective also.
  7. xj0hnx
    C.C.TX.
    I know, I ran fine with three also for a while, but as soon as I added the torque mounts, it just felt like it had more confidence, and more sturdy. I drive on the autobahn, and living over here has made me more of a "it has to be right" guy.
  8. JDMilan
    Boca Raton, FL
  9. civic_types
    civic_types Senior Member
    [/QUOTE]I drive on the autobahn
    :worthy:
  10. Sergey P.A.
    Sergey P.A. Senior Member
    253 Tacoma
    I wish I could drive on a outoban, b16vx you lucky.....
  11. xj0hnx
    C.C.TX.
    The autobahn can be really fun, but at the same time, it really grinds into you how slow Hondas really are :(. I need a slightly long 5th and a 1.8 to push it, then everything will be ok.
