deerhunter101
Hi! Ok so Ive been researching and reading through the forums for hours, figure I should try a post and see what happens. I own a 98 honda civic dx with a stock D16Y7 SOHC OBD2 MPFI. Years back the engine flooded with water in the intake which I believe caused it to seize recently. I need my car to go to school and work daily so speed is not an issue and my budget is roughly $600 might be able to push that to $800 max since im paying my way through school. So Im thinking about swapping it for a D15B JDM(1996) so Im pretty sure its obd2. The motor is completely intact minus the tranny. So I was wondering what I might have to do to the wiring harness since the jdm motor harness is on the other side? And do I need to change the ecu since they are both already obd2? Just looking to do this quickly and within budget. Any knowledge advice help welcome. And thanks for you time
Honda D15B JDM Used Engine Civic (96-00) [D15B_L] - $450.00 : Attarco, High-quality Japanese and European engines, transmissions, and auto parts
