98' ITR swap
Discussion in 'HYBRID -> ED-EF / DA' started by vsopcrxbwah, Mar 26, 2004.
  1. vsopcrxbwah
    vsopcrxbwah Junior Member
    hi im a noob trying to figure some stuff out. im planning on getting a 98 ITR swap in 6 months or so, and am gonna run it all motor. what would be some of the things i would have to do? so far i have the hasport stuff:
    -Hasport B-Series Mounts ( including hydro conversion )
    -Hasport Shift Linkage
    What would i use for axles? if i remember right cant i use the ITR ones, if you switch the left hand side seal on tranny?
    How about wiring? should i get one of the "obo chassis to obd2 "ecu conversion harnesses? then wire up the extra stuff?
    basically i need input on how to start this project. thanks :worthy:
  2. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    wire engine to obd-0 spec, its alot easier.cheaper.
  3. uptowng2ic
    uptowng2ic Member
    NY
    :withstupid: the 90-93 integra axles should work. And if you plan to use an ITR tranny get the hydro to cable conversion kit.
  4. vsopcrxbwah
    thanks for help guys. but if i wire the engine to obo 0 spec, then i wont get to use the full potential of the engine right? to wire my car to obd2 i would use the itr engine harness and plug an obo chassis to obd2b harness to connect the ecu. does any of this make sense, im trying to make it stay obd2b. anyone know what the 90-93 integra axles are rated at... hp wise? thx all i appreciate the info.
  5. uptowng2ic
    uptowng2ic Member
    NY
    If you have the money to spend....sure you can wire up the chassis to handle the ITR engine.
  6. vsopcrxbwah
    thanks guys i appreciate it :worthy:
  7. joesefcivic
    joesefcivic Senior Member
    is this brian?
  8. vsopcrxbwah
  9. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    Hasport does harness conversions if you send them both harnesses. (CRX & ITR) Don't use the 90-93 teg axles. They aren't quite long enough, so your CV boots will rip and need to be replaced quite frequently, but that shouldn't be an issue, since your running all motor and probably wanting high whp you were going to get aftermarket axles anyways right? RIGHT!! Go to RAXLES.com for that. If your crx is an SI or a DX then your steering knuckles and hubs are fine but if your CRX is a HF you will need the knuckles and hubs from an SI, DX or a 90-93 Integra. Hope that helps.
  10. vsopcrxbwah
    thanks man i appreciate the info
  11. jaydemdc2
    jaydemdc2 Member
    seattle wa
    thats not true, i ve been using axels from a 90-93 da for almost two years now, racing, launcing at high RPMs and i dont have anyproblems at all. havent had to replace them yet, boots are still in great condition and theres no clicking so you should be fine with those. i have the place racing motor mounts also if thats any help
  12. MugenCRX
    Thornton CO
    I guess my axles just suck then. :shrug:
  13. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    um....obd-0 wouldnt be the best idea. especially if you want to run hondata
  14. cycloneb18c3
    New Jersey
    its the least difficult way of installing the engine, but obd-1 would be best(most ecus for DOHC VTEC, and Hondata compatible.
    for obd-1 add distributer, injectors, ecu, conversion harness, 4 wire o2 sensor.
  15. crx_16x
    crx_16x Junior Member
    Use OBD-2 and get Apex power FC
  16. Smonkeyboy
    Spokane, WA
    for hondas
    Hondata > Fower FC.
    its an amazing tunint tool for Toyota Nissan and the like, But Hondata ownes Power FC for Hondas.
  17. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    :withstupid:
    There is no better alternative for Honda tuning. Hondata ownz j00!
  18. RSBAD454
    RSBAD454 Member
  19. b17gsr
    b17gsr Junior Member
    Ottawa, Ont.
    I've done a ITR swap into a 88 CRX Si, including the hydro tranny, and OBD2 wiring.
    Was fun. B)
