I am doing a swap into a 2000 DX hatch, I cant start that dam thing cause I used an automatic wiring harness and the ECU is a manual from a 99 civic si so I cannot start it cause it thinks the clutch is not pushed in, so I need to find out what ecu pins to tap into so I can run the wires to clutch cancel switch on the tranny, please if any of you know what pins they are on that ecu please let know ASAP cause i want to start this dam thing today...thanks!!!!
if u have auto tranny and u are using a manual ecu, other than the car not starting the car will not shift gears either. the tranny is control by the ecm
Its cool i figured it out, thanks for tryin tho, but the car was a manual, all i had at the time was an automatic HX harness to do the swap.
