99-00 factory mounts in 94 si?
Discussion in 'HYBRID -> EG-EK / DC' started by fakthepolice, May 31, 2005.
  1. fakthepolice
    fakthepolice Senior Member
    can u use the 99-00 factory motor mounts to mount a b series motor into an eg?
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    You have to use a mix match of mounts and brackets from GSR and Ex/GSR/ part SI... :unsure:
  3. fakthepolice
    which mounts would u use from which car?
  4. VTECin5th
    Phoenix Az
    What (if any) motor do you have in the EG, and what B series are you swapping into it? :huh:
  5. fakthepolice
    it has a z6 in it , and im not sure what b series either b16 or ls most likely
  6. VTECin5th
    Phoenix Az
    it is kinda hard to say exactly which mounts and brackets you will need if you are unsure of which swap you want to get and which generation swap also.
    You may need to mix match with GSR brackets and your existing mounts, but it still depends on which swap you go into.
    Come back after you have decided.
    i did a b16a2 NOT the same as SIR II, and i had to use 2 GSR brackets, and the rest i reused my existing mounts and brackets.
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yip depends on which motor you get, and which brackets it has.
  8. chicken
    chicken Senior Member
    Sacramento, California
    use mainly the mounts from an integra b series.. plus some of the eg mounts.. i got the ones from the integra if needed..
  9. xj0hnx
    C.C.TX.
    You'd want the Integra rear bracket. For the drivers side, you need ot getone that would match the bracket, and what pattern the bolts are, whether they are straight or offset (the ones off the bracket, that the mount bolts to).
