99 D16 with a 95 engine harness?
ImportManiak420
I have a 94 dx that has been swapped to a 95 d16z6 prior to me buying the car, the motor blew up on me so i found a d16 out of a 99 ex can i use the same harness from my car or is it obd2? If so can i just change over the obd2 parts to obd1 and still use the p28 ecu?
everything should plug up fine except for the distributor and the injectors
you can either change the parts out or swap out the plugs on the harness
you might need to lengthen a few wires... not 100% sure
