CTR1806
Im about to swap a 98+ spec ITR engine into my 99 honda civic EX with a d16y8. This is all the things that the ITR motor is bring with it:
Motor
- LSD Hydraulic Tranny (S80)
- ECU (P73)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Is there anything that I need....I heard some stuff about having to add wires but im not sure if i still have to seeing that the motor i order brings its factory engine harness and ECU. this is my first swap and i dont want to screw things up. Any help would be awesome. Thanks
Motor
- ECU (P73)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
