goldgreen90ef
goldgeen90ef
have any of u guys ever put 99 struts and shocks on a crx w a b16?will it make it sit up high?they have tein s techs on them so i thought it might be ok let me know thanks guys^_^
Ben said:Shocks:
If you have non-88 LCA's, any EF, DA or EG/DC rear shock will fit, but some are better than others. The DA shock, for instance, is about 1.5" longer than the stock EF shock. Just for the record, this height difference is ABOVE the perch. That means that your car will be the same height regardless of what shock you run. Travel is your friend and there is no sense in putting a longer shock in there unless you are going to raise it up and go rallying. The DA shocks, though, are valved stiffer than their EF counterpart.
