A/C hoses- WTF!
leonard3343826
check this out- jdm b16a into 95 ex.
when i pulled the d16, i left the ac compressor thinking i would just bolt it onto the b16. no.
the compressors dont match, the compressor brackets dont match (that has the nose going into the left lower engine mount), and the ac hoses dont match- do you keep your ac after a swap or do you give it up? please advise, and thanx for any input.
Search there are many posts on this. You need a 94-95 dohc v-tec delsol forward bracket or equivelent. someone here has also used the crv bracket, guess it's cheeper.
or yoy can buy an modificated a/c bracket that way your stock a/c compressor will fit in your b16 engine w/o problem ,pries are 75 to $125 check hasport.com or jdmshit.com or any other company who makes modificated parts.
