a mini me problem
Discussion in 'Civic and CRX - EF' started by seeking land, Apr 25, 2008.
  1. seeking land
    seeking land New Member
    Pierre, SD
    i did a mini me in my 90 crx and it will turn over with no problem but will not start, thats with a new dizzy too
    pls help
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    spark and fuel?
  3. seeking land
    Pierre, SD
  4. YBLEGAL
    NW Indiana
    check the voltage going to the distributor. try and go to autozone and look at the haynes manual for the distributor's original motor. there's a trouble shooting process. just trace the ignition circuit back and look for voltage. check fuses. could be a wiring issue.
  5. t3t4delsol
    t3t4delsol New Member
    York, Pa
    your obd0 on your block what head did you use obd1 or obd2 and what dizzy are you using obd0-2?
  6. seeking land
    Pierre, SD
    im useing a Y8 head and the dizzy that came with the car, its a CRX DX and the owner befor me converted it to multi port, the stamp on the dizzy reads TD-O2U
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    did it run before u did the headswap??
  8. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    is the dizzy wired up correctly for obd1??? i'd check that coulde be why
  9. YBLEGAL
    NW Indiana
    :werd: check the wiring. i didnt realize this was fresh off the swap
  10. seeking land
    Pierre, SD
    it stoped running right befor i did the head swap, right befor it died it started to spit, spater, and pop on me....then dead
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    sounds like it jumped time,or the headgasket went,,
    but as for spark,how is it wired
  12. seeking land
    Pierre, SD
    found the problem, it was 2 wires disconected from the ecu...but now its giving me another problem...when it starts it heads streait for the redline
  13. YBLEGAL
    NW Indiana
    uhhhhhhhhhhhhhhhhhhhhh, call me stupid, throttle stuck open??? lol
    i dont think it's possible without the intake air....
    unless you got one hell of a leak in the intake system after the throttle
  14. seeking land
    Pierre, SD
  15. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    check your throttle postion sensor when you do the DPFI to MPFI swap you have to swap the outer two wires around. Unless the previous owner used a harness out of a car the had MPFI but it sounds like he used the DX harness. When you do the swap with the DX harness if you dont swap the wires at the TPS sensor the ECU with read that the engine is wide open at an idle. Good luck
  16. seeking land
    Pierre, SD
    i really dont want to say it because im gana sound stupid but....there was indeed one hell of a leak lol
    sry to wast your guys time on that one lol
  17. YBLEGAL
    NW Indiana
    :D wow funny, i didnt expect to be right lol. not a problem, glad u got it taken care of. all good now?
  18. seeking land
    Pierre, SD
    its getting there, all thats left is to solder up some wires, a tune then to the strip i go
