a6 head on a b7 block
Discussion in 'General Tech and Maintenance' started by crxsi1989, Jan 31, 2010.
  1. crxsi1989
    crxsi1989 New Member
    I have been working on hondas for a few months. I have been driving a 94 honda civic with a d15b7. My exauhst valves have gone out on my current d15b7 head so now im just trying to see what i will need if I put a 89 d16a6 head on this b7 block .
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Swap all the sensors over, use the original manifolds. You can't find another B7 head? They should be all over the place for next to nothing..
  3. civic94cpe23
    civic94cpe23 New Member
    If I was you i'd drop a fresh D16Z6 on there. And call it day. Just search mini me swap and youll see complete write ups.
  4. d-mon
    d-mon what r u compensating 4?
    you should need nothing.
    d16a6 and d15b7 use the same head casting.
    d16a6 has a better cam. use the a6 cam with a y7/y8 cam pulley to compensate for the d15's shorter deck height.
    a6 intake manifold would be better then b7, but you need to swap sensors, as mentioned above.
    use your b7 distributor.
    a6 = obd0
    b7= obd1
