accleration problems
Discussion in 'Civic and CRX - EF' started by crxsib18a1, May 11, 2010.
  1. crxsib18a1
    crxsib18a1 New Member
    il
    :ph34r:just swaped my 91crx to a b18a1 and now im having accleration problems i push on the gas an its takes too long to acclerate does any one know why this could be?
  2. crxsib18a1
    il
  3. D16SiHatch
    D16SiHatch New Member
    too long relative to what?
  4. crxsib18a1
    il
    it wont even hit 2,000rpms witout struggleing? engine struggles to acceralate?
  5. crxsib18a1
    il
    just checked the injectors there good
  6. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Is the motor bogging down? does it pop or backfire? will it rev up out of gear?
  7. crxsib18a1
    il
    it just kinda backfire's alittle and it takes too long to accelerate....
  8. D16SiHatch
    any codes? hows mechanical timing?
  9. crxsib18a1
    il
    no codes no chek engine light do u think i shoul check the timing?
  10. D16SiHatch
    couldn't hurt to check. probably a dumb question but are you sure the firing order is right?
