Just about to install a ACT 8.8pd flywheel this sat and wanted to know what i should expect - I'm also installing a centerforce dualfriction clutch - thanks and let me know
I had the fidanza/clutchmaster flywheel and like it very much. I have also heard good things about the toda and Jun units. You can also consider lightening yours to 12lbs, zex, spoon. This usually becomes a chromoly issue when choosing flywheels.
just a heads up .... you need to start off differently with the lightened flywheel than you do stock
blip the RPMs a little higher than usual when taking off
that will keep it a lot smoother... if you dont youll be really jerky and probly stall a few times
youll learn this anyway ... just figured id give ya the heads up though
