Acura 1.6L (D16 SOHC VTEC) problem
Discussion in 'Civic - EP, FA, FG' started by speed488, Nov 27, 2007.
  1. speed488
    speed488 New Member
    Hi,
    My friend has an Acura 1.6EL 1998. It has the same engine as a Civc SI. His car will go dead from time to time for no apperent reason and he can't get to restart it for a couple of minutes afterwards. After a couple of retrys the car will start up and run great. When the engine runs, the car runs like new, it just turns off like that even while accelerating. What can it be?
    I'm doubting the distributor. Do you have any advice?
    Thanks
  2. awptickes
    MD
    Use a scan tool on the debug port. Fix anything that comes up.
  3. speed488
    speed488 New Member
    But there is no check engine light ON. Or is it something else?
  4. norcalgsr
    NorCal
    Could be a main relay. Take it out and look for cracks in the solder joints with a magnifying glass. If you find any you need to re solder the connections.
    Also check for ECU codes anyway because if it did throw a code at some point it will save it in the computer even if the light is not on.
  5. speed488
    speed488 New Member
    Ok cool! We'll take a look at it. Thanks
