Adding wires for a b18c swap
99sidude
Moderator
Moderator
VIP
I am putting a jdm b18c swap in my 93 eg hatch this weekend. I have done alot of research, and it is the wiring that scared me the most. There are 7 wires that I will need to add to the in-car harness and run to my new p72 in order to make this work. What is the best way to connect these wires into the correct terminals on the 3 ECU plugs? Can I just somehow run the wires into the appropriate positions on the clips alone, or do I need to go out and get the pins for the ecu clips. If so, where is the best place to do this?
Getting the pins for the ecu clips would be the cleanest way to go about it.
Hondaswap sells them for a buck a piece... seems steep but worth the time and money.
EDIT: ^ that is actually hondapartshero.com... an ebay seller
