IDMaxGuy
Ok ive searched the forum and found very little about this. I just need to know how to do it, I already know u must jump the little blue plug under the pass. side dash. Also my distributer doesnt really rotate, someone give me and idea about how far it is supposed to rotate, i already tried this and I didnt notice a difference, I jumped the blue plug and my Check Engine light came on and stayed on, my SRS light(which has been on for a month now) started flashing steadily, then rapidly, then went solid again. I was told the check engine light should do this to indicate timing has been reset. The thing I cant figure out is how far does the distributer go?? Its a F22B1, my freind said there are slots where you can rotate it, there is a little one but it is maybe a quarter of an inch long, not much. I took the bolts out and rotated the distributer around, towards the firewall, while it was running, if i went to far it tried to die, but i didnt notice a difference in idle very much, plus the bolts do not match up if i do rotate it that way. Someone please help or at least refer me to a website where I can address this problem better. Thanks in advance.
