After a Break, Jumping back in, 92 VX Head Swap D15Z1
Discussion in 'HYBRID -> EG-EK / DC' started by Spyderturbo, Aug 24, 2006.
Thread Status:
Not open for further replies.
  1. Spyderturbo
    Spyderturbo Senior Member
    PA
    Hey what's up guys, been a while since I've been on here but sadly, it's been a while since I've had a reason to be. My last swap project was my long gone 94 CX into which I put a D16Z6. Anyway, now I am about to get a 92 Civic VX Hatch! I'm psyched. I'm gonna pass on doing a B series but I really want to do a head swap. Ive read that the D15Z1 bottom end responds well to a Z6 Vtec head, giving a motor that spins nicely to 8K and throws out about 130HP at the crank I imagine. Has anyone done this swap? I know the 5 wire to 4 wire Oxygen sensor will be needed if I run a P28 but I might use the VX ECU at first. Just wondered if anyone else has done this swap. I did a search but didn't see much....
  2. Spyderturbo
    PA
    nobody else has input on this?
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Get a P28 ECU. They're not too expensive. The VX ECU will be mapped really funny (but it will read the wideband O2)- but if you can chip it with Uberdata or something, it might actually be better (tuned) than swapping straight to a P28.
    StealthMicro- you have completely the WRONG ECU for a Z6. The PR4 is a non-OBD ECU without VTEC control.
  4. Spyderturbo
    PA
    Calesta, thanks for the input, I was planning on the P28, I know I just need to run the O2 wires then, I was more curious about clearances and comp ratio's, I've heard that putting a Z6 head on a D15Z1 results in lower comp due to the dished pistons in the D15Z1 block and the larger combustion chambers in the Z6 head vs. the stock Z1 head. I think some people use PMS? pistons when they do this swap, I know the D15Z1 bottom end is supposed to be very good compared to the other D series bottom ends. Just wondered if anyone has tried this combo and if so what the reults were....
  5. Taco15
    Tallahassee Fl
    :lol: ya beat me to it. Hey stealth go get a p28. And ditch the LS ecu.
  6. phunky.buddha
    D-Series Engine Building Notes
    I've never tried it, but there's a link that might be able to help you out. The Z1 pistons are very deeply dished. If you want to try something crazy, you could try to drop in another set of pistons and still use your Z1 head, then have a cam custom ground for more performance on the Z1 too.
  7. Lowazzhatch
    Lowazzhatch New Member
    Try just swapping your cam and ecu. Im running the d15z1 in my 95 vx hatch. I got a cam from my buddy's D16z6 and swapped in the P28, that swapped me to reg. VTEC. As for pistons Im running the dome tops out of a ZC. Im also using a after market intake mani with a b-series TB and the injectors out of the Z6. I think all together I got about 70 bucks invested and about half a day of work. Makes a big difference.
  8. phunky.buddha
    Are you sure? The Z6 cam won't fit in the Z1 head.
  9. 1988hondacrxsiR1
    1988hondacrxsiR1 Banned
    Midwest
    Where Do Z1 Cams Come From Curious?;)
  10. phunky.buddha
  11. 1988hondacrxsiR1
    Midwest
    z1 from what car year and code of car duh? admin w/ a big stick and why i have a red dot for my reputation i dunno what is the deal please help? thanks ;)
  12. phunky.buddha
    You have a red dot because you have no rep yet. People give you rep points if they feel like you deserve it. Read the FAQ about it- I'm not even sure exactly how it works.
    Admins aren't here to be technical resources- we're here to run the board.
    As far as the D15Z1, it came from the 92-95 Civic VX hatchback.
  13. dtob
    dtob New Member
    That is the vtec-e which is mainly for fuel economy and not performance. All it does is shut down two vavles in low RPM.
  14. eg6sir
    this thread is over a year old.. let it die again
  15. dtob
    dtob New Member
    Didn't even notice that. Yup its gone.....
  16. Ic3
    Ic3 Newb Engine Swapper
    Ottawa Ont
    I think you have -negative rep.. I am new around here aswell but I have watched you post whore double posting every 3rd one pretending it was an accident. Also some advice you have given was false and you have posted almost non sense on some threads.
    Ic3
    -EDIT- Well it appears you are banned so looks like I am post whoring now ;)
  17. eg6sir
    appears you're posting in a dead thread
    [/thread]
Thread Status:
