after-swap garage sale
posol
RETIRED
I will be adding to this list later on... but for now, here's what i know i have.
94+ Ls tranny- unknown condition/mileage. pick up preferred at $350 full refund if returned to me in 10 days if it doesn't work. has VSS on it.
pics: https://hondaswap.com/brian/2004/tranny/
94 LS head semi-bare. i have to double check whats on it... but i think its valves only. maybe minimal valve train, def. no cams. $50
d-series (EG/z6) axles. complete $50
unmodified p28 ECU $150
94 del sol si guage cluster (7200 redline) 12x,xxx miles on it if i remember right.
d16z6 head complete with cams, vtec solenoid (cut conenctor plug, but wire is there) "VTEC" valve cover, etc $100
d16z6 dizzy complete, and will come with new in box Genuine Honda cap/rotor $100
z6 intake manifold, bare - $50
z6 fuel rail/stock 240cc saturated injectors - $35
EH6 stock fuel pump - $35
95 LS wire harness, modified for VTEC wires, and peak/hold injectors with a resistor box wiring. not sure if its 100% complete. will verify later. $100
Stillen 4-1 header for a d16z6, will probably fit other d15's as well, but can't verify. the best power maker header for a d-series on the market.
shows it's age, has coating peeling off, but has 0 leaks. $150
im sure i have more stuff... tons of misc stuff....
i will add them when i get home.
i can get pics of anything... just ask.
if you don't like my price, click you back button. i don't have time or patience to barter for $5.
ALL SHIPPING at buyers expense. Local pickup of larger items preferred.
hey can you put up a pic of the head I need camshaft caps or at least one and if you don't noe what they r they r what holds the camshaft
thanks
