Air Conditioning Question
YangpaNemsay
Vehicle in Question: EG Si
If I'm going to be removing the A/C would I have to use a belt thats designed for a Non A/C application?
Did the EG Si come w/o A/C Factory?
Could I use another D-Series Belt?
Just remove the belt. On the D and B series engines, all accessories are driven by their own belts. You can delete one without affecting anything else.
The 92-95 Si probably had AC as an option... look around on Edmunds if you're not sure.
just remove the belt like calesta said. then unbolt the condensor, and all the lines and stuff, and you're done. theres no need to replace anything
