Air flow sensor?
Discussion in 'HYBRID -> ED-EF / DA' started by timEspeed, Oct 29, 2003.
  1. timEspeed
    timEspeed Senior Member
    I finished my ZC swap a while ago and I've been working out the various problems I've been having with it. It hasn't been idling right and bogs under accelleration. My mechanic says the ECU doesn't know how much air the motor is gettting and therfore can't adjust fuel and ignition. I'm getting a code 4 (EACV I think), could this have anything to do with it? He thinks that the motor should have an air flow sensor, but I haven't heard anything about such a part on the ZC.
    thanx, in advance, for the help~
    ~timE
    BTW: I have a '91 DX with K+N filter and a custom EG Si down pipe. I'm quite sure that all the MPFI wiring is correct.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the ZC doesn't have a mass airflow sensor - code 4 is the crank angle sensor which is inside the distributor - usual suspects are incorrect camshaft timing or bad distributor
  3. timEspeed
    you sure? I've seen diagrams with the MAF labeled. By the thottle body right?
    if not...
    Could the lack of a signal from the CAS cause the bog in acceleration? I already set the timming with a new belt and water pump. I opened up the distributor and it looks brand new, i.e clean post (that electrode jobby) and rotor pick up.
    thanx for the feedback.
  4. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    That would be the MAP sensor. Manifold Air Pressure.
    All Honda's are Speed Density systems for guessing air flow, not metering it.
  5. timEspeed
    how would a motor act if the CAS was worked up wrong or not at all?
  6. timEspeed
    Ok, I thought so but just wanted to make sure. How's the Speed Density system work?
  7. Slo86GT
    The computer has a bunch of pre-clculated maps in it, and it reads throttle position and Manifold Air Pressure to guess at what the engine needs... On the newer crs, it factors in Intake Air Temperatures, also, and it works pretty good by fine tuning with the Oxygen sensor readings. The ECU will actually "learn" how an individual engine operates, as far as fine tuning fuel and timing requirements. It's a great system.
  8. NoJokE
    NoJokE Senior Member
    Thought MAP was Manifold Absolute Pressure
  9. Slo86GT
    Same difference. Absolute Pressure by definition just means that it can read vacuum or boost.
