air/fuel gages
Danabis
Member
I know for the most part they are just a light show but i wanted to know which ones you guys think work the best. Ive had a few rich/lean problems and thought i might try using one. I know they only work when your full throttle or getting off the throttle then the rest of the time they bounce but if you guys seen any that work better than others i would like to know.
get one with a real reading... not a rich/lean button... like
and then, if you have the cash, consider getting a wideband o2 sensor to get a REAL reading to feed the gauge
where can i get that gage that you show there? and where can i get a wideband o2? this is going to be on a b16 setup also little bit curious how the install works on a 2 o2 setup im guessing it will just hook up to one of the o2's not both.
having trouble finding the wideband o2's all the ones i found are for obd1 and no information about a 2 o2 setup if anyone has some info would be great.
the greddy unit was very nice and reasonable.
please avoid getting that autometer POS that flickers from left to right.
