if its reading anything its hooked up correctly. does it even move?, check your o2 sensor, if the o2 is fucked, so will ur reading be. i had that problem on my o2 sensor. on a stock, or near stock engine, it should ALWAYS change between lean and rich no matter what the mods. i have big cams and it still reads normally so i think ur o2 is messed, get a new 1 and see how that works.
