AIT and 10 code
crx-1.8
help me out please i have put obd2 in my crx and it get ne spark and the code it 10 i need help help
Please help us better answer your question by providing more details about your setup and/or your problem.
For example, please post the following:
  • car: year, make, model, trim
  • engine / transmission / ecu
  • basic mods list that applies or may apply to your question
  • fuel management, etc, and anything else that may apply to your question.
Also, please specify what is wrong or what you need help with EXACTLY. Doing this will help you get a better answer to your question.
Thanks,
The Moderating Team
i have 89 crx si and i put b16a2
obd0 ecu
no spark on cap
the 10 code pop up
how u u fix the AIT sensor?
are you running an OBD1/2 or OBD0 distributor?
How do you have the distributor wired in?
Are you using the stock harness?
What ECU are you using to run this?
which OBD0 distributor?
Have you checked the timing?
