just got a 95 ex, was in a front end accident but all was repaired by body shop, to set up and pull the frame cost $280 so i don't think it was that bad, they worked around the passanger box, when steeering wheel is center it pulls to the right, if you move the steering to the left a little the wheels straighten out and it goes straight. do you think it's an alignment thing or the frame wasn't repaired correctly??? if it wasn't repaired correctly is it fixable???
