almost ready to swap
Discussion in 'HYBRID -> EG-EK / DC' started by mrnice1058, Jul 20, 2004.
  1. mrnice1058
    mrnice1058 Senior Member
    Pa
    ok guys i am already to do my swap 97 civiclx d16 to a b16a i just wanted to know about my tranny i got the tranny on but what i was wondering is do i need to add fluid to the tranny being that the axles are out or is it ok to put it in and drive to the shop (7miles) to have the tranny fluid changed? also the hoses for the radiator should i get the one for the 99si or use the ones made for my car?
  2. mdlax1
    mdlax1 Senior Member
    On the Proverbial picked fence of Insanity....
    SI ones should work or check out some integra ones either one will work. I wouldn't suggest driving with no fluid go pick up some tranny lube.. get mom's to drive you 7 miles.. not worth the risk
    edit: get it while yoru getting the hoses lol
  3. PHOBIA
    PHOBIA Senior Member
    u can use regular motor oil too,if its that short i wouldnt worry about it.
  4. Full-Race Henry
    Full-Race Henry 9.616 @ 159.16 mph
    Full Race, AZ
    get 99-00si radiator hoses. and add the tranny fluid in during the swap. i wouldnt chance driving it without enough fluid.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    use Honda MTF "manual tranny fluid", and don't pour it in until the axles are in also, otherwise it will leak out, also your tranny takes 2.1 quarts of tranny fluid.
  6. mrnice1058
    Pa
    aight cool thanks i need to know about the fluid and how much goes in it thanks guys
