sohcslammer
Sup guys? OK, so my car is done, I just have to break it in now. Only problem is, I'm still runing the P30 with the 8000 redlimit. One of my buddies has an H22 in his accord that he just blew up. He is running a p73 ecu on it. The car is a 96, but the motor is a 95. (i know) Here is the question -
I know that there was no ITR before 96. Which would make my friends ECU obd2. But his motor is obd1. So why would the shop that swapped his motor use a obd2 ecu and jump it when they could have just used a p28?
Second question - If his ecu really IS obd2, then how is it chipped? If it is not obd2, then did Japan even have obd2?
I would like to run this ECU for the rev-limiter, but I live in CA and I need an obd2 ecu to stay legal. If I am not going to run an obd2 ecu, then I will just go obd1 and use the hondata.
Did Japan use OBD2????? If so, when was it implied?
BTW - what's the redline on a 96 p73?
B) Shadney
B) Shadney
