boosted_ek
Sup guys.. i picked up a obd2 b20.. it came with an alt. with a cut clip. It was a square four prong with a blk/yell, white/blue, white/red and white/green wire i believe.
My obd2 harness had a blk/yell, white/blue and white/red wires. I did the following.. connect the blk/yell wires, the white./blue wires. And I connect the white/red wire to the remaining to wires left on the clip. I did this because on the obd2-obd1 alt. conversion you connect the blk/yell's and the white/blues. But now my alternator is not charging. Did I screw up the wiring? If so whats the proper way to wire this clip in?
