Another engine mount Q
BlackFrog
Neighborhood Lush
VIP
I know its been asked a million times, i just need it spelled out like a 5 year old, cuz im a little slow :D
I know a C1 bolts right into a del Sol, I just need to know which mounts from the engine to use where.
Example: Use the cars tranny mount with the C1's tranny mount.
Use C1 mounts for timing belt mount.
Like that. thanks guys
-Chris
use all 3 of the c1 mounts
the 2 helper mounts are mixed/matched with d-series rubber/bseries metal... ALL of which is coevered in the Swap Articles 5th gen swap guide.
save yourself a headache buy poly mounts or solid mounts your stock mounts will not hold that long.. mine didn't.. pretty much ripped them to pieces
Thanks guys. Good pic smallsol.
B, i read through those articles, read the OBDII article, just hadnt found anything about the 5th gen. Prolly looked right past it. Thanks again guys.
-Chris
I would recommend getting mount inserts when you buy the engine. It's so much easier to do when the engine is out (at least for the rear)
