randerson165
Can you bypass a Knock Sensor at all so I can pass DEQ ???? I need to fix this problem tonight. I bought a KS from somebody off here and it was no good. If I put a meter on each end of the knock sensor (sensor end and connector end) will there be continuity ? If yes, my ks is def. bad. Can I bypass this or repair the sensor at all ? HELP !!!
