another obd1 question
Discussion in 'HYBRID -> EG-EK / DC' started by breed, Mar 24, 2004.
  1. breed
    breed Senior Member
    New York
    okay I did a search and came up with the same crap over and over. I know to convert a obd2 motor to obd1 you have to change the dizzy.injectors and ecu but my question is does it matter if the dizzy is out of a d series car or is there even a differance between a b series dizzy and a d series dizzy?
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I asked the same question and was told that you cant use a D-series dizzy on any B-series motor. I have the same problem... Got an OBD2 computer, and an OBD1 dizzy...
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    yes it matters.
    d series motor = d series dizzy
    b series vtec motor = b series vtec dizzy
    b series non vtec motor = b series non vtec dizzy
  4. breed
    breed Senior Member
    New York
    did you try to use the d series dizzy on the b series motor yet
