another procedure from hell
Discussion in 'Computers, Games, Electronics etc' started by pissedoffsol, Jul 28, 2005.
  1. pissedoffsol
    Yup, another one. :lol: I keep finding myself writing these god-aweful stored procedures for reporting.
    The run down:
    This is a quality assurance reporting tool.
    managers/qa people listen to recordings, and fill in how the agent did per question...
    EE = exceedes expectations
    ME = meets expectations
    RI = remidial something or other
    NA = not applicable.
    EE and ME are both worth 1 point. RI is worth 0.
    NA's are not counted towards the score, nor the total.
    csr = customer service rep.
    Q1-Q8 are for the etiquette portion of the review, and Q9-Q18 are for the accuracy, and thus need to be calculated seperately.
    and don't laugh at the pony club..... this just happens to be the program that the procedure was written for.
    ok, lets let the code do the talking....
    Code:
    SET QUOTED_IDENTIFIER ON
    GO
    SET ANSI_NULLS ON
    GO
    ALTER  PROCEDURE PonyClub_Monitoring_Report
    @startdate datetime,
    @enddate datetime,
    @csr varchar(100)
    AS
    begin
    set nocount on
    declare @queryString varchar(8000)
    declare @queryString2 varchar(8000)
    declare @queryString3 varchar(8000)
    declare @queryString4 varchar(8000)
    declare @queryString5 varchar(8000)
    create table #report_temp
    CSR varchar(30),
    TotalCallsMonitored int,
    Q1 int,
    Q2 int,
    Q3 int,
    Q4 int,
    Q5 int,
    Q6 int,
    Q7 int,
    Q8 int,
    ETIQUETTE_Points int,
    ETIQUETTE_Total_NA int,
    ETIQUETTE_SCORE varchar(20),
    Q9 int,
    Q10 int,
    Q11 int,
    Q12 int,
    Q13 int,
    Q14 int,
    Q15 int,
    Q16 int,
    Q17 int,
    Q18 int,
    ACCURACY_Points int,
    ACCURACY_Total_NA int,
    ACCURACY_SCORE varchar(20)
    ----------- check for 0 records.... will "divide by 0" error out if not pre-tested.
    declare @testquery varchar(8000)
    declare @ucount float
    	if @csr = 'ALL'
     begin
     	select @ucount = count(*) from tPonyClub_monitoring
     	where iacc_date between cast( @startdate + ' 00:00:01' AS varchar(30) ) AND cast( @enddate + ' 23:59:59' AS varchar(30) )
     	AND csr is NOT NULL
     end
    	else
     begin
     	AND csr = @csr
     end
    if (@ucount = 0)
    	begin
     select '<h5>Error, no records for agent(s) selected in specified date range</h5>'
    	end
    else
    	begin
    --------------------------------main---------------------------------------
    set @queryString = 'INSERT INTO #report_temp ' +
    'select csr AS ''CSR'', count(*) AS ''TotalCallsMonitored'', count(case q1 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q1'', ' +
    'count(case q2 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q2'', ' +
    'count(case q3 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q3'', ' +
    'count(case q4 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q4'', ' +
    'count(case q5 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q5'', ' +
    'count(case q6 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q6'', ' +
    'count(case q7 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q7'', ' +
    'count(case q8 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q8'', ' +
    'count(case q1 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q2 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q3 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q4 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q5 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q6 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q7 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q8 when ''ME'' then 1 when ''EE'' then 1 else null end)
     as ''ETIQUETTE_Points'', ' +
    'count(case q1 when ''NA'' then 1 else null end) + count(case q2 when ''NA'' then 1 else null end) +
    count(case q3 when ''NA'' then 1 else null end) + count(case q4 when ''NA'' then 1 else null end) +
    count(case q5 when ''NA'' then 1 else null end) + count(case q6 when ''NA'' then 1 else null end) +
    count(case q7 when ''NA'' then 1 else null end) + count(case q8 when ''NA'' then 1 else null end)
     as ''ETIQUETTE_Total_NA'', ' +
    --------------- start hell ------------------------------
     'cast(round((cast(count(case q1 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q2 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q3 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q4 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q5 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q6 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q7 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q8 when null then null when ''NA'' then null when ''RI'' then null else 1 end) as float)
     	(count(case q1 when ''NA'' then 1 else null end) +
     	count(case q8 when ''NA'' then 1 else null end))
     ((count(case q1 when null then null else 1 end) +
     	count(case q2 when null then null else 1 end) +
     	count(case q3 when null then null else 1 end) +
     	count(case q4 when null then null else 1 end) +
     	count(case q5 when null then null else 1 end) +
     	count(case q6 when null then null else 1 end) +
     	count(case q7 when null then null else 1 end) +
     	count(case q8 when null then null else 1 end)
     ) * 100
     ,2) as varchar(20)) + ''%'' as ''ETIQUETTE_SCORE'', '
     ---------------------- end hell -----------------------------
    set @querystring2 = 'count(case q9 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q9'', ' +
    'count(case q10 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q10'', ' +
    'count(case q11 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q11'', ' +
    'count(case q12 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q12'', ' +
    'count(case q13 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q13'', ' +
    'count(case q14 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q14'', ' +
    'count(case q15 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q15'', ' +
    'count(case q16 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q16'', ' +
    'count(case q17 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q17'', ' +
    'count(case q18 when ''ME'' then 1 when ''EE'' then 1 else null end) as ''Q18'', ' +
    '(count(case q9 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q10 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q11 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q12 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q13 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q14 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q15 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q16 when ''ME'' then 1 when ''EE'' then 1 else null end) +
    count(case q17 when ''ME'' then 1 when ''EE'' then 1 else null end) + count(case q18 when ''ME'' then 1 when ''EE'' then 1 else null end))
     as ''ACCURACY_Points'', ' +
    'count(case q9 when ''NA'' then 1 else null end) + count(case q10 when ''NA'' then 1 else null end) +
    count(case q11 when ''NA'' then 1 else null end) + count(case q12 when ''NA'' then 1 else null end) +
    count(case q13 when ''NA'' then 1 else null end) + count(case q14 when ''NA'' then 1 else null end) +
    count(case q15 when ''NA'' then 1 else null end) + count(case q16 when ''NA'' then 1 else null end) +
    count(case q17 when ''NA'' then 1 else null end) + count(case q18 when ''NA'' then 1 else null end)
     as ''ACCURACY_Total_NA'', ' +
     'cast(round((cast(count(case q9 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q10 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q11 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q12 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q13 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q14 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q15 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q16 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q17 when null then null when ''NA'' then null when ''RI'' then null else 1 end) +
     	count(case q18 when null then null when ''NA'' then null when ''RI'' then null else 1 end) as float)
     	(count(case q9 when ''NA'' then 1 else null end) +
     	count(case q18 when ''NA'' then 1 else null end))
     ((count(case q9 when null then null else 1 end) +
     	count(case q10 when null then null else 1 end) +
     	count(case q11 when null then null else 1 end) +
     	count(case q12 when null then null else 1 end) +
     	count(case q13 when null then null else 1 end) +
     	count(case q14 when null then null else 1 end) +
     	count(case q15 when null then null else 1 end) +
     	count(case q16 when null then null else 1 end) +
     	count(case q17 when null then null else 1 end) +
     	count(case q18 when null then null else 1 end)
     ) * 100
     ,2) as varchar(20)) + ''%'' as ''ACCURACY_SCORE'' '
    set @querystring3 = 'from tPonyClub_monitoring ' +
    'where iacc_date between ''' + cast( @startdate + ' 00:00:01' AS varchar(30) ) + ''' AND ''' + cast( @enddate + ' 23:59:59' AS varchar(30) ) + ''' '
    	if @csr = 'ALL'
     begin
     	set @queryString3 = @queryString3 + ' and csr is NOT NULL '
     end
    	else
     begin
     	set @queryString3 = @queryString3 + ' and csr = ''' + @csr + ''' '
     end
    	set @queryString3 = @queryString3 + ' GROUP BY csr'
    --------------- TOTALS ------------------
    	set @querystring4 = ' INSERT INTO #report_temp ' +
     'SELECT ''TOTALS'' as ''CSR'', count(*) as ''TotalCallsMonitored'', ' +
     'count(case q1 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q2 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q3 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q4 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q5 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q6 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q7 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q8 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q1 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q2 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q3 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q4 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q5 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q6 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q7 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q8 when ''NA'' then 1 else null end), ' +
     ) * 100
     ,2) as varchar(20)) + ''%'' , ' +
     'count(case q9 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q10 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q11 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q12 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q13 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q14 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q15 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q16 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q17 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q18 when ''EE'' then 1 when ''ME'' then 1 else null end), ' +
     'count(case q9 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q10 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q11 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q12 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q13 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q14 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q15 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q16 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q17 when ''EE'' then 1 when ''ME'' then 1 else null end) +
     	count(case q18 when ''EE'' then 1 when ''ME'' then 1 else null end)	, ' +
     	count(case q18 when ''NA'' then 1 else null end), '
    	set @querystring5 =
     ) * 100
     ,2) as varchar(20)) + ''%'' as ''ACCURACY_SCORE'' ' +
     	if @csr = 'ALL'
      begin
      	set @queryString5 = @queryString5 + ' and csr is NOT NULL '
      end
     	else
      begin
      	set @queryString5 = @queryString5 + ' and csr = ''' + @csr + ''' '
      end
    	exec(@querystring + @querystring2 + @querystring3 + @querystring4 + @querystring5)
    select CSR,
    TotalCallsMonitored AS 'Total Calls Monitored',
    Q1,
    Q2,
    Q3,
    Q4,
    Q5,
    Q6,
    Q7,
    Q8,
    ETIQUETTE_Points AS 'Etiquette Points',
    ETIQUETTE_Total_NA AS 'Etiquette N/A',
    ETIQUETTE_SCORE AS 'Etiquette Score',
    Q9,
    Q10,
    Q11,
    Q12,
    Q13,
    Q14,
    Q15,
    Q16,
    Q17,
    Q18,
    ACCURACY_Points AS 'Accuracy Points',
    ACCURACY_Total_NA AS 'Accuracy N/A',
    ACCURACY_SCORE AS 'Accuracy Score'
    from #report_temp
    end -- still need to drop, cuz table was created before testquery string
    drop table #report_temp
    end
    GO
    SET QUOTED_IDENTIFIER OFF
    GO
    SET ANSI_NULLS ON
    GO
    and that makes a pretty little table :)
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    /gumby
    My 'ead 'urts!
  3. pissedoffsol
    that's why i make the big bucks... :)
    err..... the medium bucks :p
  4. Battle Pope
    Yeah, I know. I understood most of it, just not how it all works. I'm very much a novice with the coding.
    I'm doing much better with numbers anyway. :)
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Pony Club.. :lmao:
    oh, sorry, you said not to do that, didn't you...
  6. pissedoffsol
    at least you didin't wait until this thread was 5 months old to do that....
  7. Battle Pope
  8. b204dr
    b204dr Senior Member
    Minnesota
    b we have some thing of that sort- ever heard of e-talk agent view!
  9. pissedoffsol
    never heard of it.
    i write all my own code :p
