Another rear disc brake question with simple answers hopefully
Discussion in 'Wheels / Suspension / Tires / Brakes' started by RoughKnight, Jun 30, 2010.
  1. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    So...looking to upgrade to discs, done some research, came across two possibilities:
    Rear disc swap from a teg
    Rear disc swap from a EG hatch si
    here's my question: whichever one I decide to use, when I decide to lower the car on struts/springs, do I have to order the front ones for my car then a seperate two for the rear? It could be a stupid answer, but I want sound of mind. I'm guessing that if I get lucky and get the EG si I won't need a different part number, but what about the teg? Different size bushings? Blah blah blah I'd like to know all the similarites and differences, I googled a bit and found diddly. Thanks!
  2. tabKola
    tabKola New Member
    Tewksbury MA
    The EG and 94-01 Integra discs are exactly the same, so no, you won't need to order different struts/springs just get EG ones.
