Any And All Sol Owners
Discussion in 'HYBRID -> EG-EK / DC' started by koi_killa, Feb 13, 2003.
  1. koi_killa
    koi_killa Junior Member
    Ok, i have had it. I have lived with it for this long and cannot go any longer. Does your tops make noise while moving? It might sound liek a stupid question, but i am serious. Ever since i had the car, the top had been making noise. I know the car was in a prior accident (passenger side front), but i dont think that that could have cause the body to be stressed enough to be missalined. I once heard that I need to re-grease the seals, but i havent tries that yet. I know, i am lazy.
    I dont know, any ideas?
    thanx
    Zee
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    try to lube the seals a little.. other than that...
    www.teamdelsol.com
    has a little how to on tightening it up involving some washers and stuff i think.
  3. E_SolSi
    lube the seals..... that will almost definatly solve your problem
    get some 100% sylicone lubricant (the tube and the spray)
    go over all the rubber seals in the car with the spray
    then go back to the seals on the top and goo the fuck out of them with the tube shit... let it sit there like that for a while (20 min ) so it can soak into the rubber well... then wipe off the extra.... do this once a month if you can... if not do it whenever the top gets noisy
    if this doesnt fix it then try the tightening thing on www.teamdelsol.com
    incase your parts store people are stupid, and look at you like you have a 3rd eyeball when you ask for the sylicone lubricant in the tube... ask for Dielectric grease (used for spark plugs n shit)
  4. koi_killa
    Ok, thatynx a bunch both of you. I'll try it out adn let you know what happens.
    Thanx again
    Zee
