any difference between cable/hydro clutch?
Discussion in 'Engine Building' started by thompy.mark, Mar 23, 2008.
  1. thompy.mark
    thompy.mark New Member
    I bought a new clutch for my build a while ago, thinking that I would be using an S1 cable gearbox, and the guy i bought it off said it would be fine. I can no longer get in touch with him, and have moved plans to either an S4C or S80 hydro box. My question is: will the clutch that I have fit into a hydro box, or is there some inherent difference in a clutches for cable and hydro boxes?
    thanks in advance for your help :)
  2. thompy.mark
    thanks for clearing that up :)
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
  4. dtob
    dtob New Member
    There is however a difference in the throw out bearing so if you are buying a kit get the correct one for the tranny.
    I made that mistake......
